"Failed to evaluate data types" error message appears under specific circumstances when browsing an OPC UA server using the OPCUA32 client driver in the editor
When browsing variables in the editor using the OPCUA32 client driver with a specific OPC UA server configuration in the zenon OPC UA server, an error message from the OPC UA server may appear in the editor following the browse of the server data model.
An issue has been addressed in the zenon OPC UA server in the process gateway where an invalid datatype was used for variables in the runtime with a REAL datatype. In such a case, the OPCUA32 client driver could produce an error message following the browse of the server. Now the datatypes are handled correctly by the OPC UA server in the process gateway.
Issue Number: 31406
Fixed on Date: 10.12.2015
Versions: 7.60 0 BUILD 36068
    • FAQ: How can I browse an OPC UA Server using the zenon OPC UA Client Driver?
    • How to setup the zenon OPC UA Driver with a self-signed certificate
    • How to setup the zenon OPC UA Driver with a CA-signed certificate
    • How to use certificates for OPC UA security
    • OPC-UA Server: DNS Name used in certificate created by zenon.
