Externally visible variables are not updated in Logic if variablename is changed in lower-/uppercase
In zenon Logic externally visible variables were not updated under certain circumstances. This behavior has been fixed.
If in zenon Logic
variable names are modified only in upper/lower case, but the name itself
remains the same, externally visible variables are no longer updated. As a
result, no communication is possible. Also no error message is displayed. The "Visible externally" property must be disabled and re-enabled for each affected variable to trigger updates
again.
This behavior has been modified. Every change of the
name is handled correctly, even if only lower case is modified to upper case or
vice versa. Externally visible variables are thus always updated correctly even
after only changing the case.
higher.
Item ID: 263937
Version: 11.00 Build: 157700
Logic Service: zenrt_write function doesn't update variables and locks writing from other sources
Description After the execution of the zenrt_write function to update the value of the zenon variable externally visible in zenon Logic, the variable values in zenon were no longer updated and could not be changed by any meaning. According logs, the ...
Defining externally visible variables for a specific zenon Logic project via the "Externally visible for" property in the zenon Editor does not work correctly.
Summary If a variable has "Externally visible" enabled, entering the name of a specific zenon Logic project in the "Externally visible for" property should only display the variable in the defined Logic project. The variable in this case is available ...
Performing "online change" in zenon logic after adding variables to zenon with activated option "externally visible" and reload of the zenon runtime the variables in zenon are not linked correctly to the corresponding variables in zenon logic. As a result, the added variables don`t have a value in zenon logic.
Summary When zenon runtime is active, adding variables in zenon with option "externally visible" active and having also enabled "On Line Change" in zenon logic, the values in zenon logic corresponding to the added variables in zenon do not have a ...
