In Extended Trend, when "Modify time period" is used, its default option "Use current time period" is not handled correctly and behaves like "Use last completed period".
This has been fixed for version 11 and higher.
Current behavior:
- Version 8.10 up to and including 10:
It is not possible to use the mode "Use
current time period" for "Modify time period".
- Version 11 and higher:
All "Modify time period" modes work as intended. Note that if a past time period is to be displayed, the Trends refresh rate must be set to zero.
