Extended Trend curves not displaying when first curve is not active
When a Extend Trend screen displays more than one curve, if the first curve is disabled by the user (active off) and the remaining curves are still active, these also aren't shown >> Are also cleared from the trend. Note: this only occurs if the first curve in trend list is not active. For example, if there are 3 curves on the trend and if the second is not active (set by the user) and the first and third are still active, these two continue to be shown correctly in the trend.
Data from archive is loaded even if the first curve is not shown
Issue Number: 30451
Fixed on Date: 30.9.2013
Versions: 7.10 0 BUILD 7770
