Execution of "Redundancy switch" function does not work correctly in the runtime when using the hardware redundancy mode
When using the hardware redundancy mode in the project, the function "redundancy switch" does not execute properly in the runtime. The role of the active server does not switch after executing the function.
An issue has been addressed in the runtime where executing the function redundancy switch was not executed. Now the function redundancy switch allows switching the primary server with hardware redundancy mode. Other functionality of the function "redundancy switch" is disabled when using hardware redundancy.
Issue Number: 36378
Fixed on Date: 24.5.2016
Versions: 7.50 0 BUILD 28986
