Executing SAP function calls modifies the values of variables linked at import parameters when linear value adjustment is configured
When a variable has linear value adjustment configured and it is linked at a SAP RFC function as IMPORT parameter, the value adjustment will be applied to the variable when executing the SAP fanction.
An issue has been addressed where linear value adjustment was incorrectly applied to a variable which is used at a SAP function when this SAP function is being executed. Now the variable value will remain unchanged when the SAP function is executed.
Issue Number: 31805
Fixed on Date: 5.5.2014
Versions: 6.51 0 BUILD 27 | 7.10 0 BUILD 13311
    • [SAP Interface] Values of export parameters of SAP function are not assigned to variables
      Summary Two bugs occur in the SAP Interface: In the Service Engine, zenon variables are not updated correctly. And in the Engineering Studio, import/export parameters are swapped when importing RFC function configurations. These two bugs occur ...
    • Checklist: SAP Interface does not work
      Time estimate:  30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Checklist usage: #. [Quick ...
    • Allocation target variables do not correctly consider non-linear value adjustment
      Summary A target variable used at an allocation that has macros linked for non-linear value adjustment, doesnot call the AdjustScadaValue macro prior to writing the value if the source variable at the allocation changes the allocation is triggered ...
    • displaying ** in numeric element when using "value linear adjustment"
      Description Variables are adjusted with a value range of 0...9999 and 0...10000 with linear value adjustment: Logic studio adjustment to 9999 and setpoint default for Service Engine 99.99. If the value is set to the upper limit in Logic studio (value ...
