even when starting the runtime with zenKeyBlock the combination Win+L is not blocked
ZenKeyBlock may be used to prohibit access to Windows functions via keyboard shortcuts. Howeer, the key combination Win+L may still work.
Unfortunately it is not possible to temporarly (while runtime is active) disable this key combination. It can only be deactivated permanently. To activate this, a new checkbox ('disable Windows key') has been introduced in the options dialog in the startup tool.
Issue Number: 32155
Fixed on Date: 29.1.2015
Versions: 7.20 0 BUILD 17768
Multitouch system gestures are not blocked by zenKeyBlock
Summary when starting zenKeyBlock, the zenon Runtime will start and block all key combinations to access OS features (like Alt+F4). Multitouch gestures, however, are not blocked. Description when starting zenKeyBlock, the zenon Runtime will start and ...
the key combination Ctrl+Alt+Tab is not blocked by zenKeyBlock
Summary Executing zenKeyBlock will start the zenon runtime and block all keyboards shortcuts which are normally used to access OS features (like Alt+F4). However, the key combination Ctrl+Alt+Tab is not blocked in windows 8 operating systems. This ...
zenKeyblock shortcut 'WIN + L' locks Win Key
Description The Tool Keyblock Service Engine Start locked the Windows key after the combination Windows + L was used. The issue has been addressed and the behavior is now as expected. To benefit from this fix: Update your zenon Software Platform to ...
The zenkeyblock.exe application is not available for the 64 bit runtime
Summary The zenkeyblock.exe application is not available for the 64 bit runtime Description The zenkeyblock.exe application is not available for the 64 bit runtime Solution The zenkeyblock.exe is now also available for the 64 bit zenon runtime and is ...
When starting the runtime twice the second runtime produces an unhandled exception.
Summary When starting the runtime twice the second runtime produces an unhandled exception. DescriptionWhen starting the runtime twice the second runtime produces an unhandled exception. Solution An issue has been resolved so that the second runtime ...
