Evacuating archives to MySQL does not work
Evacuating archives to MySQL does not work. An unhandled exception occurs when creating tables.
Cause:
The problem is caused by an "unknown error" if CreateCommand fails when called after StartTransaction in the MySQL ODBC driver 8.0.33.0.
Solution:
Use MySQL ODBC driver version 8.0.21.0. This works correctly with zenon.
Item ID: 263919
Version: 11.00 Build: 157700
    • Machine Event Counters Report not working any more in zenon 12
      Description In Report Engine version 12, the reports "Machine Event Counters", "Over Revolutions on Load Shedding" and "Active Power on Load Shedding" no longer work after they have been updated from a previous version. The error states that the ...
    • The SE reports an unhandled exception when closed while an evacuation to the Data Store is running
      Summary The Service Engine reports an unhandled exception while evacuating data to Data Storage. This has been fixed. Description The Service Engine reports an unhandled exception if data is being evacuated to Data Storage while the Service Gateway ...
