Euromap63: When original primary server comes up again in dominant zenon network, the driver is not able to start communication to the euromap server again
When the original primary server came up again in a dominant zenon network, the EUROMAP63 driver in some cases was not able to resume communication to the EUROMAP server again.The issue has been addressed by improving the way how the EUROMAP63 driver initiates the communication again on the primary server.
Item ID: 283616
Version: 14.00 Build: 314355
Version: 12.00 Build: 301428
Version: 11.00 Build: 314353
FAQ: Initialization of Internal variables (Network) in Dominant redundancy mode.
When (re-)starting the dominant Server 1, regardless of their 'Remanence' configuration, internal variables with calculation in 'Network' are initialized first in the dominant Server 1 and only after synchronized with the running Server 2. Modules ...
FAQ: How can I monitor and react on the communication status of my devices with zenon?
