EUROMAP63: driver get stuck and cause high CPU load when dat file is wrong
The EUROMAP63
driver hangs due to an error in the DAT file. Thereby it causes a high CPU
load. The error is caused by unquoted ASCII fields and empty fields. These do
not comply with the Euromap standard.
This problem has been solved. The driver
now accepts these small deviations from the standard in the DAT file and runs
as expected.
- Update your zenon Software Platform to the
latest build of zenon 11 or higher.
Item ID: 258852
Version: 11.00 Build: 157700
EUROMAP63: In specific scenario when a machine is providing a .DAT file which has the header located in the middle of the file this results in reading in an endless loop by the driver which also leads to a huge amount of log entries in the diag viewer
Description Issue in the EUROMAP63 driver when parsing a DAT file provided by a device, where the header is not in line 0, but in some lines in the middle (e.g. line 9). The driver reads the file in an endless loop, resulting in a large number of ...
Sending many GSM SMS messages caused high CPU load of the zenon runtime and could cause the zenon runtime to stop responding
Summary When many GSM SMS messages are sent from the zenon runtime simultaneously, the runtime causes a high CPU load and may stop responding. DescriptionWhen many GSM SMS messages are sent from the zenon runtime simultaneously, the runtime causes a ...
CTI driver has high CPU load in combination with slower communication processor/ PLC
Summary The CTI driver has a unusual high CPU load when it communicates to specific (older versions, slower,TI 5x5 Plcs) The CPU load is arround 40-60%. Description The CTI driver has a unusual high CPU load when it communicates to specific (older ...
