Euro map 63 redundancy not working for few minutes
Redundancy is not working with EM63 driver as expected
Data is not gathered in both servers’ session folders, because EM63 driver is generating the same UREPGEN.JOB files, and the machine cannot perform 2 jobs with the same name.
It is noticeable, when primary server is killed (restarted or process task is ended in task manager), then ABORTALL.JOB file is not sent to primary servers’ session folder, meanwhile secondary server won’t generate UREPGEN.JOB file, while the job is still running in first servers’ session folder.
Please take a look on picture attached.
End result is, that redundancy is only working properly only when primary server is closed down properly (all EM63 drivers are stopped correctly), but on a real-case scenario, when primary server RT crashes or the server is restarted or shut-down immediately, in order for the RT software to continue working properly it has to be restarted.
Issue Number: 247518
Fixed on Date: 3.3.2022
Versions: 10 0 BUILD 97200
