ETM : X-axis Time Disappearance and Time Difference, zoom+, Backward/Forward function error
The Extended Trend display no longer showed X-axis time values and presented a blank diagram because the trend's zoom/scroll state became inconsistent after repeated backward and rezoom actions. This also caused the curve list to display no values, prevented zoom+ from functioning, and reversed the Backward/Forward navigation behavior.
Item ID: 315992
Version: 15.00 Build: 611020
    • Extended Trend Screen can not be zoomed on the x-Axis (Time-Axis) if Lot Filter is applied directly
      Summary When displaying data based on a lot filter on an Extended Trend screen, you can not zoom on the x-Axis if the Lot Filter in the Screen Switch Function is set to "Apply Lot filter directly". Fix: Even when lot(s) are filtered directly, the ...
    • SE: ETM - zoom out completly on Y axis - SE crashes
      Description The zenon Service Engine closed unexpectedly after a zooming out procedure in the ETM screen. The issue was triggered by trying to extend the time range beyond Year 2038, where the traditional 32bit signed integer wraps to -1. The ...
    • ETM: Curves lines are drawn backward in time even if the option "sort data" is active
      Description In ETM the option "Sort data" has been activated for drawing the curves. Nevertheless, curves are also drawn backwards in time. Apparently, the values in the archives were not sorted by their time stamp. A possible cause could be that the ...
    • Checklist: VBA code compilation error
      Time estimate:   15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Error still occurs after ...
