ETM: the cursor output list only shows the amount of curves which were active when switching to the ETM screen. When more curves are activated / deactivated the cursor output list does not show a proper amount of curves and wrong values.
The cursor output list always shows the amount of curves which were set active in the screen switch function. When curves are activated / deactivated in the ETM screen the output list is refreshed but always shows the same amount of curves. So either other curves are removed from the list when activating different curves or when deactivating curves than activated ones are listed multiple times in the cursor output list. When having curves shown several times in the list they show different values as the duplicated curve values are not refreshed (see screenshot).
Reworked the refresh an reinitialisation routines
Issue Number: 31030
Fixed on Date: 16.12.2013
Versions: 7.20 0 BUILD 17768
ETM: cursor output in diagram only works if screenswitch has active curves
Summary For a diagramm with integrated scan list, on "Cursor on" each active curve is shown in the scan list, regardless of how many curves were activated in the screen switch function. Description For a diagramm with integrated scan list, on "Cursor ...
ETM: Cursor output window only shows data until "now", not from curves that are in the future.
Description If a time filter in the ETM is set in the future, the cursor output window only displayed data until "now", but not from curves that are in the future. The issue has been addressed and now the correct values are displayed in the cursor ...
ETM cursor output list displays incorrect value for minimum and maximum
Description The values for variable minimum and maximum were not correctly displayed in the ETM screen element cursor output list. The issue has been addressed and the behavior is now as expected. To benefit from this fix: Update your zenon Software ...
ETM: Curves lines are drawn backward in time even if the option "sort data" is active
Description In ETM the option "Sort data" has been activated for drawing the curves. Nevertheless, curves are also drawn backwards in time. Apparently, the values in the archives were not sorted by their time stamp. A possible cause could be that the ...
