If you display archive data with type of scan "on change recording" the gantt curve will not be lengthen until a value change has been performed. Gantt curve will be lengthen if: Type of scan is "cyclic scanning" Gantt curve will not be lengthen if: Type of scan is "on change recording"
When reading data for a gantt diagramm from an archive, the graphic is extended till the endtime of the archive.
Fixed on 15.01.2013 , available from 7.00 SP0 Build 6
