ETM - Gantt chart is invisible with standard settings
When you activate the Gantt chart in the extended trend and you leave the default setting for "Line width" (=0), then the Gantt chart isn't displayed. The problem is, that the standard setting = 0 and this setting is treated different in the Gantt chart: standard curve: (Line width = 0) == (line width = 1) = curve with a line width of 1 pixel Gantt chart: (Line width = 0) == no line The line width for the Gantt chart should be treated the same way as for standard curves.
Gantt chart now uses a default width of 1, if configuration is left at starting value of 0.
Fixed on 16.01.2013 , available from 7.00 SP0 Build 6
Issue Number: 26349
Fixed on Date: 16.1.2013
Versions: 7.00 0 BUILD 6 | 7.00 0 BUILD 7
