ETM: Export displayed trend data doesn't work correctly with following archive
If you use the "export displayed trend data" function in the runtime with a normal archive, all informations are exported correctly in the .txt file. If you export a following archive the identification and the unit are missing in the .txt file, althoug the same variables are used.
with the fix the export has been improved. It works now as expected.
Issue Number: 33068
Fixed on Date: 11.11.2014
Versions: 7.11 0 BUILD 16009
FAQ: After updating to zenon 7.20 I dont see newly SQL evacuated historian data anymore in the trend (ETM), Report Generator, Report Viewer and Archive Revision, only the former evacuated values are displayed.
Summary Solution There is an available update, see Article ID195426 / ID165155. We highly recommend to update to the linked build ID195426 If you do not update, there is a Workaround Change the GUID column of the table from CHAR to VARCHAR. With ...
Extended Trend-> Export displayed data": the ID of the variable is not exported correctly by using language file."
Summary "Export displayed data" function in Extended Trend does not translate variable identification and unit Description "Export displayed data" function in Extended Trend does not translate variable identification and unit Issue Number: 220209 ...
Following archives doesn't shows data in trend screen
Summary The property "select suitable aggregation archive automatically" is activated in the sreen switch function to a trend screen, this functionality does not show data in trend with following archives. DescriptionThe property "select suitable ...
