ETM: cursor-window is not updated correctly when the visiblity of trend curves is taken from a variable
deactivate and activate the cursor again after curves have been added or removed
Issue Number: 160602
Fixed on Date: 14.12.2018
Versions: 8.00 0 BUILD 53974
ETM: Cursor output window only shows data until "now", not from curves that are in the future.
Description If a time filter in the ETM is set in the future, the cursor output window only displayed data until "now", but not from curves that are in the future. The issue has been addressed and now the correct values are displayed in the cursor ...
ETM - Multi-select and multi-edit possibility for trend curves
Summary ETM allows multi select and multi edit for trend curves. Description From now on, both in the Engineering Studio as well as in the Service Engine, several curves of Extended Trend can be edited at the same time. To enable quick changes, ...
extended trend cursor scanning does not show milliseconds
Summary At the moment the scanner windows does not show the milliseconds, only the axis in the trend is capable of showing the milli seconds. If the ETM Property for the x-Axis is set to show Milli Seconds (Scale - MS) -> also the scan Window should ...
ETM: the cursor output list only shows the amount of curves which were active when switching to the ETM screen. When more curves are activated / deactivated the cursor output list does not show a proper amount of curves and wrong values.
Summary The cursor output list always shows the amount of curves which were set active in the screen switch function. When curves are activated / deactivated in the ETM screen the output list is refreshed but always shows the same amount of curves. ...
ETM: cursor output in diagram only works if screenswitch has active curves
Summary For a diagramm with integrated scan list, on "Cursor on" each active curve is shown in the scan list, regardless of how many curves were activated in the screen switch function. Description For a diagramm with integrated scan list, on "Cursor ...
