Ethernet IP Scanner with lost Connection leads to a cycle time increase until the Connection is reastablished.
Add a Ethernet IP Adapter configuration in the Project, add a Scanner connection to connect (local) to this Adapter. At least the local Connection will never be disconnected and it prevents this situation where the issue shows up.
