eSignature can be bypassed by keyboard elements
In the Recipegroup Manager (RGM) it was possible to bypass eSignature. The value was written instantly to the variable although the eSignature dialog popped up.
The issue has been addressed and the value is written now to the variable after the eSignature dialog has been displayed.
To benefit from this fix:
  • Update your zenon Software Platform to the latest build of zenon 10 or higher.
Item ID: 286553
Version: 14.00 Build: 293273
Version: 12.00 Build: 289185
Version: 11.00 Build: 314353
Version: 10.00 Build: 314352
    • eSignature screen is not opened when setvalue action is done via keyboards (e.g. SETVALUEKBD)
      Description The eSignature screen did not open when the setvalue action was performed using the keyboard. The issue has been addressed and the eSignature screen opens now as expected. To benefit from this fix: Update your zenon Software Platform to ...
    • eSignature CEL entries are not logged when setting values via RGM
      Description When setting values in the RGM directly from the SETVALUEKBD keyboard (via the control element Write set value), the eSignature dialogue appeared but the CEL entries were missing. This issue has been addressed and the CEL entries are now ...
    • eSignature & keyboard shortcut: consecutive dialogue is restarting midway
      Description If ENTER was used as a keyboard shortcut, the eSignature dialogues for changing a variable value and an RGM parameter were not displayed correctly. Because of this, the process had to be completed twice. The issue has been addressed and ...
