Enumerated Data Type variable in zenon logic Smart Object template doesn‘t appear in the Project
SOT Enumerated data types are not displayed correctly in zenon Logic project instance. This has been fixed.
Smart Object Template (SOT): In zenon Logic project instance the enumerated data types from the Smart Object Template are not displayed.
In SOT (Smart Object Template) the data types are displayed correctly. But the variables are missing in the zenon Logic project of the instance.
This behavior has been fixed. Enumerated data types are now displayed correctly.
Item ID: 255683
Version: 11.00 Build: 109317
    • Renamed references do not rename zenon logic programs when updating the SOT
      Description In a project references of a Smart Object Template (SOT) are renamed. When updating the SOT, zenon Logic programs are not renamed accordingly. The original names are still included. This behavior has been changed. When renaming ...
    • How to get the IIoT Dashboard Service running with data from the Service Engine
