The external storage of data for AML and CEL via the "Storage location" and "Continuous export" properties is only possible if the "Ring buffer and historical data" entry has been selected for the "Save AML data" respectively "Save CEL data" property. However, these should also be available with the "Default" setting. This is because on PC "Default" means "Ring buffer and historical data" and Windows CE is not supported.
This behavior has been adjusted. The properties "Storage location" and "Continuous export" are now available for configuration if the property "Save AML data" respectively "Save CEL data" has been set to "Default" or "Ring buffer and historical data". They are still not available for "Ring buffer only".
