Engineering Studio can not import the user file modified by linux service-engine
If a zenon_hash.ini under Linux was used, a [Hash] NetworkPasswordCryptKeyBase that was empty or only with ':' was invalid. e.g:":::"
The same happened with the combination of spaces and ':', used as a value forbidden. e.g. " : :: "
Under Linux, when the user configuration in the Service Engine was modified, the password.cmp file was written in an incompatible format. If a project has an unloadable password.cmp now the file has to be newly transferred from the Engineering Studio
 The issue has been addressed and the behavior is now as expected.
To benefit from this fix:
Item ID: 302731
Version: 15.00 Build: 518139
