Empty 'variable name' column in CEL for messages from RGM
The Recipe Group Manager, when writes a recipe, creates in the Chronological Event List entries where 'text' contains name of the recipe, new and old values of the variables and names of the variable. But the column 'variable name' of such CEL entry is empty. Therefore, it is not possible to use e.g. the lot filter for such messages.
Now CEL entry shows the RGM information not only in 'text' but additionally in columns 'variable name' and 'value'.
Issue Number: 31971
Fixed on Date: 25.5.2014
Versions: 7.11 0 BUILD 12493
In CEL the filter on variable name is not working correctly with option "Always include system messages"
Summary In Chronological Even List the filter on variable name displays all variables when option "always include system messages" is also active. When "always include system messages" is deactivated – the filter works correctly. DescriptionIn ...
Messages are not sent properly when using "Following Call" and user group name from string variable
Summary If desired user group name for "Send Message" function is taken from a variable, the first user receives a message. If this message is not acknowledged, the next user does not receive a message and the following CEL entry is created: "End of ...
The Full User Name" column content is removed in the CEL, when the user is deactivated"
Summary Full name users is displayed in cel and aml even if the user is deactivated. Description Full name users is displayed in cel and aml even if the user is deactivated. Information Using the "User Name" column only, but this doesn't work for the ...
RGM: if signature text edited by the operator is not correctly logged in the CEL on the client
Summary In RGM, the signature text edited by the operator is not logged correctly in the CEL on the client. This error has been fixed. Description If a recipe value change with editable signature text is executed in the RGM on the client for "Recipe ...
FAQ: It seems that sometimes not all variables are correctly written to the PLC by the RGM module, although the system driver variable states that the recipe was written successfully and the option "write synchronously" is active. How can this be?
When reading a RGM recipe immediately after writing a RGM recipe, with a driver that has the option "keep update list in memory" active, and recipe variables that have been read previously, it can happen that a read cycle is currently in progress, ...
