Elements with visibility variables linked placed on screentype faceplate are not displayed if screen is opened a second time
For screens of type Faceplate, elements whose visibility is controlled by a variable are not displayed correctly. The behavior occurs from the second time the screen is opened.
To fix this issue:
  • Update to the latest build of zenon 10 or 11.
Item ID: 253449
Version: 10.00 Build: 102631
    • Visibility lost after Importing Screen XML file
      Description During XML import of screens, already existing elements sometimes lose their visibility settings. Linked variables for controlling visibility are not applied. These settings need to be reconfigured. This behavior has been modified. ...
    • FAQ: What is the time zone and time format used in zenon Software Platform products and what needs to be considered?
      When you ask someone what the time is, they'll usually be able to tell you. But when you ask them what date and time sunrise was yesterday in a different country on a different continent, in a different hemisphere it gets less easy. Terms like GMT ...
    • Under specific circumstances the visibility of screen elements takes some time to adapt in the Runtime.
      Summary When the visibility of screen elements is taken from an interlocking it may take some time to adapt their visibility to the result of the linked interlocking in the Runtime. DescriptionWhen the visibility of screen elements is taken from an ...
