EIP Scanner does not work on Linux machine with 2 Ethernet ports
The EIP Scanner failed to start IO on Linux with two Ethernet ports. This occurred because the connection showed "I/O connection OK" but did not actually exchange IO data when multiple NICs were present.
Item ID: 241446
Version: 10.00 Build: 85877
