Editor exits unexpectedly when clicking in a cell in a Report Generator screen that uses a ComboBox
Editor stops working when clicking in a cell in a Report Generator screen that uses a ComboBox element. This effect is very rare and hard to reproduce.
An issue was addressed in the Report Generator which in very rare cases could lead to a NULL reference which makes the editor quit. Now, this effect is no longer reproducible.
Fixed on 20.06.2012, available from 7.00 SP0 Build 1, available from 6.51 SP0 Build 14, available from 6.50 SP0 Build 14, available from 6.22 SP1 Build 21
Issue Number: 27090
Fixed on Date: 20.6.2012
Versions: 7.00 0 BUILD 1 | 6.51 0 BUILD 14
FAQ: What is the difference between the zenon Report Generator and the zenon Report Viewer?
zenon Editor closes unexpectedly, when deleting a combobox list which is used in a report
Summary When a "combobox list" is used in a cell of a Report Generator and this list is deleted the zenon Editor closes unexpectedly. DescriptionWhen a "combobox list" is used in a cell of a Report Generator and this list is deleted the zenon Editor ...
zenon Runtime closes unexpectedly, if between Report Generator profiles is switched too fast
Summary With too fast switching (via screen switch function) between Report Generator profiles Runtime stopped unexpectedly. DescriptionWith too fast switching (via screen switch function) between Report Generator profiles Runtime stopped ...
Editor exits unexpectedly when two reports are opened in combination with a multi-user project environment
Summary In a multi-user environment, a client creates a report in the Report Generator. If another client creates a report and opens the report of the first client, the editor closes unexpectedly when trying to synchronize the multi-user project. ...
When using a format file from the Report Generator (*.xrs) for the display of the recipe table in the Recipegroup Manager screen, hidden cells are not filled.
Summary When displaying a Recipegroup Manager recipe in the Recipegroup Manager screen in the runtime, it is possible to display the recipe table using a format file from the report generator, in order to have a custom design table. In version 6.50, ...
