Editor crashes in some cases when the ENTER key is pressed just after an undefined variable
In zenon Logic the Logic Studio is closed
directly after pressing the Enter key. This can be triggered by a variable
without definition.
This behavior has been changed. The Logic
Studio does not exit now. A hint is shown to define undefined variables.
To take advantage of this fix:
- Update to the latest build of zenon Logic
11.
Item ID: 254436
Version: 11.00 Build: 104641
It should not be possible to enter negative values for the variable's hysteresis in the Editor.
Summary It should not be possible to enter negative values for the variable's hysteresis in the Editor. DescriptionIt should not be possible to enter negative values for the variable's hysteresis in the Editor. Solution It is no longer possible to ...
zenon installation without provided zenon Demo-Workspace causes undefined state of the zenon Editor.
Summary If the zenon setup was carried out without the provided Demo-Workspace and the zenon Editor was started afterwards, it may occur that the zenon Editor is in an undefined state. This appears, if a workspace was loaded. In fact the issue arises ...
MATHDR32: Undefined variable in formula causes driver stop during Runtime Start
Summary MATHDR32: Undefined variable in formula leads to a stop of the driver when try to initialize the formulas. Description MATHDR32: Undefined variable in formula leads to a stop of the driver when try to initialize the formulas. Solution ...
