[EdgeGateway Setup] Missing start parameter when installing "Gateway Services" causing EdgeGateway to crash
The Edge Gateway crashed, even if is installed as a service. The crash is caused by the absence of the "-c" in the corresponding zenon6.ini entry (should be: PARAM_2 = -c -se).
The issue has been fixed and the Edge Gateway runs as a console application again, when started with the zenStartupManager.
Update your zenon Software Platform to the latest build of zenon 14 or higher.
