The column visibility in the Edge Gateway has been reset on all columns, when there were misconfigurations. A misconfiguration is a configuration in which not every stored column was valid or in which the total amount of valid ones is less than 22 columns.
The issue has been addressed and the column visibility works only for the desired columns.
Item ID: 287171
Version: 14.00 Build: 293273
