Dynamic text color from a variable does not work in certain cases when variable limit uses palette colors
When a numerical value and dynamic text element use text color from a variable limit which itself uses a color palette for limit color definition, the color is not set correctly.
However when the color is set static, the colors are taken from the limit correctly.
An issue was addressed in the color palettes which prevented the correct color to be taken.
Now, the text color of the element can be defined by its limits of the linked variable, no matter if these colors at the limit are fixed colors or colors from the color palette.
Issue Number: 23756
Fixed on Date: 6.11.2012
Versions: 7.00 0 BUILD 4
