Dynamic limit texts are displayed in the output window as missing key words
When creating Service Engine files, there is a warning about missing keywords, which in fact are available. The misleading warning is no longer displayed.
When creating Service Engine files, the output window displays warning about missing keywords for dynamic limit texts. The message refers to texts with the scheme %@TEXT_ INDEXED KEYWORD. However, the keywords are included in the language table.
Cause:
Indexed keywords are not considered when creating the Service Engine files. This leads to the error message.
Solution:
Indexed keywords are no longer displayed as missing.
Tip:
Make sure you use the correct syntax.
Instead of
%@TEXT_ INDEXED KEYWORD use:
  • @TEXT_
    or
  • %@TEXT_+INDEXED KEYWORD
To benefit from the fix:
Item ID: 256143
Version: 11.00 Build: 109317
