Dublicated entries after CSV export from CEL
In zenon 8.20, exporting the CEL to a CSV
file via the function “Export CEL” leads to duplicate entries.
Cause:
With zenon version 10, the export of keywords for AML
and CEL was implemented. This functionality was also made available for version
8.20. This merge down of the new functionality caused the error.
This error has been fixed.
- Update your zenon Software Platform to the latest build of zenon 8,20.
Item ID: 224478
Version: 8.20 Build: 68579
"Export CEL" function cuts off the Limit Value Text (by using CSV Export)
In some cases the "Export CEL" function will cut off the Limit Value Text (by using CSV Export) by projects converted from older versions. To fix this effect you need to create a new "Export CEL" function in actual version.
FAQ: How to troubleshoot and resolve High CEL Log volume
Diagnosis: Identify the offending variables To address high Chronological Event List (CEL) log volume, first identify which variables are generating excessive events. Open the CEL screen in the zenon Service Engine (Runtime) (or in File Inspector). ...
AccessDNP3_SG: enhanced support for CSV import / CSV export
Description [Feature]: The AccessDNP3_SG Process Gateway CSV export/import function did not support double bit binary inputs. The functional gap has been addressed and the handling of double bit binary inputs is now supported in CSV export/import ...
CEL: CSV Export does not take over column settings as defined in the project properties
Summary Default CEL and AML columns are not consistent in every module Description Default CEL and AML columns are not consistent in every module Information The problem can be "fixed" by adding columns like "identification" in the CEL column ...
