Drivers visible: driver can be closed with "x" when zenDrvOpsManager communication is used
Drivers can inadvertently be closed when the option "Driver invisible" is not set. This has been changed.
If the "Driver invisible" option is not set, the active drivers are visible in the Service Engine and can be closed via the task bar windows. This leads to an invalid state of the variables in the Service Engine, because there is no restart mechanism.
This has been changed. Attempting to close the driver via the taskbar window will now not close the driver.
Item ID: 256398
Version: 11.00 Build: 109317
