DRIVERS update priorities are no longer considered after reload
When using different priorities for updating variables, all variables are reset to normal priority after a reload due to a change in the driver. After a restart of the Service Engine or a start and stop of the driver, the variables are updated correctly.
This behavior has been modified. Variables are updated with the correct priority after reloading.
Item ID: 259853
Version: 12.00 Build: 206562
Version: 11.00 Build: 193390
    • Engineering Studio: Add Driver 'Siemens : S7 driver for S7-1200/1500' to Zenon Project - Error when starting driver
      Summary The S7TIA/S7 for S7-1200/1500 driver cannot be started. This issue has been solved. Description The attempt to add the driver S7TIA/S7 for S7-1200/1500 to a project fails in some constellations with an error message (Error code 0x8001011f). ...
    • At redundancy switch of zenon servers, a variable with "alternative value" (ALT_VAL) suddenly gets the INVALID bit added - breaking ALC
      Description When a variable with INVALID status gets switched to "alternative value" some drivers on the active server add status ALT_VAL and remove status INVALID for this variable. After the standby server takes over the active role (redundancy ...
    • FAQ: Update CE proceedure
