Driver Simulation Wizard: Simulation project is not createad when there are variables with umlauts
The Driver Simulation Wizard supported IEC 61131-3 compliant characters (standard letters, numbers, and underscore "_").
Variables with non-ASCII characters weren't encoded with correct codepage.
The wizard did not set „Accept non IEC compliant variable names“ in the simulation project and could not handle special characters in variable names.
Now also the following characters are supported: "Ä", "ä", "Ö", "ö", "Ü", "ü", "-", "/", "\", "[", "]", "!", "$", ".", and space " ".
Issue Number: 154421
Fixed on Date: 18.2.2019
Versions: 7.60 0 BUILD 55240 | 8.00 0 BUILD 55271
