Double Cursor present wrong value "1" even the 1st/2nd cursor's var value is "0" when time difference is "0"
In Extended Trend, the double cursor shows the wrong average value “-nan(ind)” when using numeric variables, even if the value of the 1st and 2nd cursor is “any”. The problem occurres when the double cursor’s time difference second is set to “0 second” (milliseconds unit). In any other condition, the average calculation works normal. The cause for the wrong value was a division by zero, as the value "false" corresponds to "0" for Bool.
This error has been corrected. The average value is now calculated correctly
Item ID: 280101
Version: 14.00 Build: 239777
Version: 12.00 Build: 232473
Version: 11.00 Build: 242382
Version: 10.00 Build: 232665
