A vulnerability has been reported in implementations of older versions of a specific Ethernet/IP stack from RTA (Realtime automation), that may still be used today.
The vulnerability has been rated critical, with a CVSSv3 score of 9.8.
The zenon logic K5BusEIPs / T5BusEIP - EIP adapter fieldbus driver makes use of the Ethernet/IP stack from RTA.
From version 7.50 (straton 9.0) and higher, where the K5BusEIP fieldbus driver is included, a newer version of the Ethernet/IP stack from RTA is in use, which is not affected by this vulnerability.
There may be OEM devices that make use of the straton runtime with a K5BusEIPs fieldbus driver that still make use of an older, vulnerable, version of the RTA Ethernet/IP stack.
In doubt, please contact your OEM device vendor.
Further information can be found here:
https://www.claroty.com/2020/11/17/blog-research-rta-enip-stack-vulnerability/
ICSA-20-324-03
Real Time Automation EtherNet/IP | CISA
CVE-2020-25159
NVD - CVE-2020-25159 (nist.gov)
