Distributed Engineering. Issue regarding the versioning of project backups of multiuser projects.
The version number didn't increase after a project-backup of a multiuser project was created.
Cause of this problem was the timing of increment of the version minor number: it started before the project was loaded after the backup creation, and could be overwritten by the synchronization. Now the project is loaded first and then the version is incremented and synchronized to the server.
There exist a workaround by manually altering the version numbers in the project.ini's.
Issue Number: 34893
Fixed on Date: 19.8.2015
Versions: 7.11 0 BUILD 22146 | 7.50 0 BUILD 25796
