At the zenon Editor (x86 & x64) with a multiuser global and standard project, alarm areas in the standard are lost after synchronization if they are linked to a global equipment group.
An issue has been addressed at the multiuser - projects operations for the AML-items. Now, Alarm Areas in a multiuser project work as expected, regardless of order of actions or if the Alarm Areas node is currently opened while they are "Checked In".
Workaround:
Basically,
Create WSB on MU Server
Restore WSB on new PC
Convert to single user (Workspace -> Save As)
Create/Edit Alarm Areas as necessary
Export Alarms via XML
Transfer XML back to MU PC
Import Alarms into MU Project via XML
Then the links to the global equipment model are permanently.
