Digital sampling trace in zenon Logic Editor. Clicking on the Radio button Each cycle in the settings of the digital sampling trace leads to an error message when no value was entered in the lower TextBox and then trying to change a tab in the dialog.
When no value is entered for the sampling period in the settings of the digital sampling trace and then clicking on the Each cycle radiobutton, an error message appears when trying to change to an other tab in the dialog.
This issue has been addressed by greying out the TextBox for the sampling period when the radiobutton Each cycle gets clicked.
Issue Number: 33745
Fixed on Date: 6.4.2016
Versions: 7.50 0 BUILD 27465
    • FAQ: How to address Logic service cycle overflows?
      In some cases, Logic Service may not respect the configured cycle time of the Logic application. When this happens consider the following: Check Windows Event Logs - System Event ID = 37: The speed of processor x in group y is being limited by system ...
    • Externally visible variables are not updated in Logic if variablename is changed in lower-/uppercase
      Summary In zenon Logic externally visible variables were not updated under certain circumstances. This behavior has been fixed. Description If in zenon Logic variable names are modified only in upper/lower case, but the name itself remains the same, ...
    • Zenon Logic: OEM specific blocks and functions are marked as not supported after coverting a project from zenon 12 to zenon 14
      Description When converting from zenon 12 to zenon 14, OEM specific functions and blocks for zenon Logic are marked as "not supported". This is due to a name change in the "Select" tab of the "Target System Configuration" dialog. "Logic Runtime for ...
