DiagViewer - Enhanced usability
Diagnosis Viewer has been enhanced.
The file ending was changed from *.txt to *.dvlog. Double-click on the DVLOG file to open the Diagnosis Viewer.
To filter the columns in the Diagnosis Viewer, Regular expressions (Regex) are supported.
In the Filter configuration dialog for the Time interval it is now possible to select different time zones. The start and end time for the time interval is adjusted automatically to the selected time zone.
For the Filter configuration dialog in the Colors tab, we expanded the options for selecting the display color. Operation has been made more intuitive.
Filter profiles can also be exported and imported.
The filter profiles include:
  • Server configuration
  • Client configuration
  • Column settings
Item ID: 246806
Version: 12.00 Build: 153415
    • KIEBACK.exe driver enhanced serial port support
      Summary The kieback.exe driver has been enhanced to support communication of up to 256 COM ports Description The kieback.exe driver has been enhanced to support communication of up to 256 COM ports Issue Number: 153418 Fixed on Date: 16.10.2018 ...
    • The logging for the KUKA Driver should be enhanced.
      Summary In the diagviewer SetInfo, Cancel and OnSetInfo of the KUKA Driver will not be logged. DescriptionIn the diagviewer SetInfo, Cancel and OnSetInfo of the KUKA Driver will not be logged. Solution This issue has been addressed by adding logging ...
    • inconsistant usability behavior in zenon logic profinet device configuration
      Summary zenon logic profinet device configuration: there is an edit box instead of toggle check box when editing the master properties « Initialize IOxS » and « I/O communication only from within cycle » there is an edit box instead of a ...
    • AccessDNP3_SG: enhanced support for CSV import / CSV export
      Description [Feature]: The AccessDNP3_SG Process Gateway CSV export/import function did not support double bit binary inputs. The functional gap has been addressed and the handling of double bit binary inputs is now supported in CSV export/import ...
    • AddIn does not start - Exception displayed in Log (DiagViewer)
      In case that an AddIn (Service or Wizard) does not start and the log shows an exception message likewise equally to that below check the software development of the AddIn. Scada.Internal.DotNetAddInExtension.AddInIntegration.Startup Cannot startup ...
