Deploying Report Engine Reports as IIoT Services Resources does not work
In Reporting Studio,
a report can be made available as a resource for IIoT Services.
To do this, the user must log in to the IIoT
Services in a browser window. In
some constellations, the login is aborted with an error message that says:
"Could not load file or assembly ... The
system cannot find the file specified."
This error has been fixed.
- Update your zenon Software Platform to the latest build of zenon 10 or
higher.
Item ID: 263801
Version: 11.00 Build: 157700
Version: 10.00 Build: 138660
FAQ: Is it possible to run zenon Report Engine as a service?
Most of the components of the zenon Report Engine are running as a service. These are: SQL-Server (MSSQL$ZA2019) Reporting Services (ReportServer$ZA2019) SQL-Server Agent$ZA2019 for scheduled tasks License Service (zrsLicSrv). Only the Service ...
IIoT Services API delivers the wrong report parameter data type, equipment tree nesting or time filter granularity when the report parameter name contains an underscore
Description In the Report Engine, a parameter name with an underscore is used in a report. If this report is deployed with the "Available in IIoT Services" option active, the IIoT Services API returns the wrong report parameter data type, the wrong ...
