Denial of Service vulnerability in WVS Ops-Manager
The WVS OPS Manager contains libraries from other software manufacturers. In one of these applications - YARP - a vulnerability was discovered that allows Denial of Service attacks.
This vulnerability has been fixed.
The version of YARP used in the WVS OPS Manager has been updated to:
  • Version 1.1.2 for zenon 11 and 12
  • Version 2.0.1 for zenon 14
Item ID: 268901
Version: 12.00 Build: 180966
Version: 11.00 Build: 176384
    • FAQ: WVS and Ops Manager in combination with zenon network redundancy
      It is possible to start the Web Visualization Service Ops Manager on the respective servers and it is also possible to start the Ops Manager on specific PCs. The most distributed architecture can be seen in the following picture: Possible network ...
    • Using AddIn in combination with WVS
      Can AddIns be used in WVS? Simple answer: yes, but... Types of AddIns, Types of WVS There need to be distinguished between a AddIn Service and an AddIn Wizard. Whereas the first is started and stopped and reacts in between on events is the latter ...
    • Checklist: WVS does not work
      Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Perform a build update to the latest version. In the ...
