Deleting of an Referenced Smart Object Template causes Zenon to Crash
Deleting a referenced Smart Object Template (SOT) causes zenon to exit unexpectedly. This error has been fixed.
A SOT contains a zenon Logic project and a variable that
is externally visible for zenon Logic. This SOT is
referenced by another SOT. If the SOT with
the reference is deleted, the Engineering Studio terminates unexpectedly.
This error has been fixed. Deleting referenced SOTs
works as expected.
To benefit from this
fix:
- Update your zenon Software Platform to the latest build of zenon 14
or higher.
Item ID: 280816
Version: 14.00 Build: 239777
SOT: Export of selected screen as XML leads the Engineering Studio to crash
Description If in a Smart Object Template (SOT) a screen is exported as XML, this leads to a crash of the Engineering Studio. This error has been fixed. Screens can be exported as XML in a SOT again. To benefit from this fix: Update your zenon ...
ES: Unsaved Smart Object reference causes crash on subsequent reference creation
Description The Engineering Studio closed unexpectedly when a reference to an unsaved Smart Object Template was created. The issue has been addressed and the behaviour is now as expected. To benefit from this fix: Update your zenon Software Platform ...
SOT replacing rule does not work after change on SOT if SOT is referenced in other SOT
Description A Smart Object Template (A) is referenced in another Smart Object Template (B). After changes in SOT A, the already existing Smart Objects of SOT B are unusable. Screens no longer work. However, newly created Smart Objects work as ...
