Deleting an interlocking for a recipe variable of the Recipegroup Manager in the variable parameters dialog using the keyboard is not saved persistently.
When deleting an interlocking for a recipe variable in the Recipegroup Manager module using the keyboard "del" key in the "change variable parameters" dialog, the interlocking appears to be deleted, however this is not saved. After closing and reopening the dialog, the interlocking is shown again.
An issue has been addressed in the Recipegroup Manager module, where deleting an interlocking in the editor via the keyboard was not properly saved. Now the interlocking is deleted correctly.
Issue Number: 24378
Fixed on Date: 12.3.2013
Versions: 7.11 0 BUILD 10238
FAQ: When I activate the option "write synchronously" for the Recipegroup manager recipe, and I write the recipe, the recipe does not seem to be written properly and also the Service Engine does not close properly. Why is that?
When the option "write synchronously" is active at a recipe, when writing a recipe (sending values to the PLC) for each recipe variable a writing confirmation is requested to the driver. On a successfull write, the driver sends a writing confirmation ...
Changed column settings in the dialog for editing a Recipegroup Manager recipe in the editor are not saved in multi-user projects
Summary When changing the column settings in the dialog for editing a Recipegroup Manager recipe in the zenon editor, the changed column settings are not permanently saved in multi-user projects under specific circumstances DescriptionWhen changing ...
A filtertext for the recipe value filter at the screen switch function to the Recipegroup Manager screen is not saved
Summary When using the Recipegroup manager it is possible to define recipe value filter at the recipe variables in the editor. These filters can be used to filter the recipe value list in the runtime. At the screen switch function these filters can ...
FAQ: When I change something in the Recipegroup Manager via the programming interface in Service Engine, these changes are not updated in the screen. Why is that?
To understand this, you have to know that each time you access the RGM (Recipegroup Manager), you are working with a copy of the RGM data. So every screen that is opened in the Service Engine, has it's own copy of the RGM data. Also each instance ...
The Recipegroup Manager function with the parameter "read recipe" does not correctly consider unit switching which may result in an error and a recipe that is not saved
Summary When using the Recipegroup Manager function with the parameter "read recipe", the scaled value through unit switching is used and validated against the min. / max. boundaries of the raw value stored in the recipe. This may result in a value ...
