The 3D Integration stores only the camera position, but not
the camera target position.
Definitions:
- Camera position: The camera position
represents the 3D point in the room from which the camera is viewing the scene.
It determines where the camera is located relative to the objects in the scene.
- Camera target position: The camera's
target position represents the 3D point in the room that the camera is aiming
at. It determines the center of the scene that the camera is currently
capturing.
Solution:
To ensure that camera positions are visible when you
apply them, now the default camera target position is used. This corresponds to the
position when the model is opened.
- Update your zenon Software Platform to the latest build of zenon 10 or
higher.
