DATEI32: driver only reads a single file per update cycle, potentially resulting in a backlog that cannot be cleared
The File Driver only reads a single file per
update cycle, which can lead to a backlog that can no longer be cleared. It is
expected that up to 100 files are read per read cycle, the oldest files
first.
This behavior has been adjusted. The File Driver now
reads up to 100 files per cycle. A backlog is no longer built up.
- Update your zenon Software Platform to the latest build of zenon 7.60 or
higher.
Item ID: 157244
Version: 7.60 Build: 54483
Summary - Description - Issue Number: 157244 Fixed on Date: 5.12.2018 Versions: 7.60 0 BUILD 54483 | 8.00 0 BUILD 53974
FAQ: Update CE proceedure
Checklist: Software Platform build update fails
Checklist: Update CE fails
Checklist: Communication to TwinCat via BeckhoffNG driver
Time estimate: 30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. TwinCAT ADS communication library ...
