Datei32 driver crashes if write folder is set to a file instead of a folder
The File Driver is terminated if a file is specified as the destination instead of a folder. This has been fixed.
Paths for reading and writing are configured for the FileDriver in the "Settings".  The selection dialog only offers folders. However, the direct entry in the field also allows a file name to be entered. If a file name is entered instead of a folder, the driver is terminated unexpectedly on the first write attempt.
This behavior has been modified. A file as the target no longer leads to unexpected termination when writing.
Tip: Select the destination folder via the file selection dialog instead of entering it directly.
  • Update your zenon Software Platform to the latest build of zenon 8.00 or higher.
Item ID: 172498
Version: 8.00 Build: 55271
