Data Storage evacuation stops working and won't fix itself once the connection to the Data Storage gets interrupted
Retry to write meta data after loss of connection did not work and was now implemented to fix this bug.
Restart Service Engine or force a reload of the Service Engine project
Issue Number: 241097
Fixed on Date: 0.0.0
Versions: 10 0 BUILD 85877
Wrong edit and insert behavior in Screen Archive revision for Service Grid Data Storage evacuation
Summary The archive revision screen functionalities are now correctly enabled/disabled based on if the archive file is already evacuated to Data Storage or not. Additionally: based on the wrong detection, the save changes function was also not ...
Evacuation/Export to Data Storage: Improve behaviour if evacuation is not possible
Summary Improved behavior for evacuation/export to Data Storage. Description External storage and continuous export of AML and/or CEL to SQL/database tables or Data Storage has been updated: Up to version 12: The buffer for entries not yet exported ...
CEL Data storage cannot resume
Description External Storage and Continuous Export of CEL and AML data to a SQL database and IIoT Services Data Storage was getting corrupted and permanently stopped. This happened when metadata and transaction container Service Engine files became ...
