Data points with the same COA/IOA address but different Typ-ID are overwritten.
Values for variables with the same COA/IOA address but different and not compatible Type ID are overwritten by IEC870 driver. This behavior has been changed.
In non-standard conforming RTUs there can be 2 IOs with the same COA/IOA but different Type ID, the difference being in the value format and not just the time tag. If one of those is configured as a zenon variable, and the IEC870 driver receives an ASDU for the other IO (mismatched Type ID), the value gets incorrectly assigned to the zenon variable. Its value is overwritten and thus corrupted. This behavior has been changed.
Solution:
The driver assigns the value of ASDUs to
the zenon variable only if the Type ID of the
ASDU is compatible with the Type ID of the
variable. Compatible in the meaning of the IEC 60870-5-101/104 Standard; e.g. T01, T02 and T30 are compatible (a signal with or without time information).
When receiving ASDUs with incompatible Type ID, the value is ignored and an error is
logged; e.g. T01 and T03 are not compatible (two different signals/value encoding).
- Update your zenon Software Platform to the latest build of zenon 10 or
higher.
Item ID: 259574
Version: 11.00 Build: 115310
Version: 10.00 Build: 116257
IEC870 driver (Master): online import creates T00 variables with wrong name and COA value
Summary By online import from PLC the IEC60870 Master driver (zenon / zenon Logic) proposes to create also variables for 'connection status' - two variables of Type ID = 0 and with IOA=0 ("connection status") and IOA=1 ("status of Data Link ...
FAQ: How can I backup the Service Engine data, the data created during Service Engine?
The path of the Service Engine folder can be amended in the project properties and it is set into zenon6.ini (VBF30=) when the start project is set in Engineering Studio or in zenon Startup Tool. In the Service Engine folder, there is the subfolder ...
